Hello. I have a 17000 gallon chlorine pool in the Houston TX area. I used stabilized chlorine and shock for too long and it raised my CYA to 100ppm. Drain pool about a foot of water added fresh water and it only lowered it to 90 ppm. One pool store says I need to be below 80ppm and to keep lowering. The other PS says as long as your lower than 100 I’m good. Any thought? Also I switched over to unstable shock and that’s all I have been using since cya went up high. PS says it’s the same as using liquid chlorine. I add 1 pound of shock every 3 days and it keeps chlorine between 2-3 ppm. But I feel I need to use liquid chlorine as well
