frustratedpoolmom said:Is anything falling in your pool, leaves - organics? that could explain the FC loss...
usual stuff, skimmer & netting keeping it in check, April we get lots of pollen & May we get lots of cottonwood tree junk. Cedar trees deposit their junk when the wind blows. Usually bird dropping if we take the cover off too late etc but none AT ALL this year (till today, a fluke I suppose). I did inquire re pump run time. I was 24/7 but then TFP OK'd a reduction, so I did, about 8 hours/day (two 4-hr segments). Want me to raise pump time? If it won't help then forget it. Through all this I've wondered about those cedar tree droppings. Its not a new thing but answer this: if there was an amonia issue in past years, its quite possible that my wife & Leslies would never know about it, right? Or would there be signs that something was wrong? The other thing I thought of is that I want to learn TFP's closing techniques & what to do over the winter because what if that was the source of error
So I think at this point it is safe for you to assume that you reached your target, and just test in the morning....and if you are less than 14 on the FC then you likely had a drop again.
OK
Got it
I'm so sorry Johnny!
This is indeed a drag. I told my wife I'd take over the pool this year & use "a better & cheaper way to do it"- she laughs at me & often reminds me she spent less at Leslies for a season compared to what I went through in a few weeks, implying this TFP way isn't the way to go. I explained the amonia issue. But remember I went to Leslie's at your request & their test results indicated "to raise the pH a bit"- nothing close to all the technical help TFP offered. Wants to know "why don't you just drain some?" Why aerate, what a waste of electricity, why not just add the stuff we have on hand to raise pH, ?" The whining aside, she did operate the pool fairly problem free (key word fairly) since 1992 & now I take over & all this- can you imagine yourself in this scenario? If I can get to a point where the amonia issue is resolved, maybe if I add borates my wife will be impressed? For now, I look silly to her
(Last year we had a gal who wasn't hitting her target...she was using bad bleach from a dollar store. IT took the retesting 1 hour after addition a few times to figure that out, once she switched bleach brands her pool cleared.)
I was clear to check the concentration of the bleach
So many said "I see the end in sight". I don't- at all.
frustratedpoolmom said:(We have discussed your situation behind the scenes.)
I figured
It's very likely the ammonia is gone. Your FC drop during the day is normal, you have very minimal overnight FC loss, so it's unlikely to be from the ammonia at this point.
Want a free Petsmart ammonia test?
During the day, the CC drops to .5, so the sun is destroying the CCs.
Bleach destoys the CC too? Just trying to learn
I would say you could try a "normal" schedule for a the next week and see what happens. Keep an eye on your water...if it changes color, looks dull or cloudy, etc. or you see algae you may have to shock again.
OK, I do know how to shock
Keep your FC between 3 and 7, you'll have to add enough chlorine each day to make sure it doesn't drop below 3.
Nightly I test it, & add bleach with a Target of 7 whenever it is under 7, right?
If ever a nightly test reveals < 3 then shock w Target 15, right?
No early am tests needed? Or maybe the 1st day or 2 to verify I'm > 7 or above & not < 3?
Do your normal maintenance, vacuming, backwashing the filter, etc., make sure you check any areas that don't get good circulation, etc. brushing - all that boring stuff....you want all the crud (leaves, etc.) out each day so it's not using up your FC.
Nothing new to me. My pump run-time is OK, about 8 hours/day (two 4-hr segments). ?
At the end of the week, do an overnight test to see if the FC is holding, and keep us posted.
Oops, this answers my above question. "Holding" means: I test 1 hr after adding bleach & verify I reached or exceeded Target, then the am test to verify I didn't drop > 1 FC from the Target , right?
If the others don't agree with this plan, they will let you know.
Apparently they agree, but I'll be checking
Thanks to everyone.
Johnny B said:To keep this thread short (ha ha), I'll try to post several days of test results in one post after the end of the week overnight test unless I have questions sooner
Johnny B said:Because I’m only hoping to see a FC of 4 in the evenings, this FC of 5 would usually mean no bleach added tonight
