The shades of red at the upper scale don't seem to be easy to distinguish in Taylor test kit for pH, and readings don't show anything above 8.0. My pool seems to naturally want to level out on the higher end (due to recent build/plaster and SWG). Trying to keep lower just ends up a fight in futility in adding muriatic acid every other day. Based on suggestions from those here, I've adjusted my pH target to be 7.8 and tweaked the other goals accordingly to get to a slightly negative CSI.
With the test kit I don't see much difference in 7.8 vs 8.0, and since the test tops out at 8.0 there's no what to know how high your pH may be. I find that adding a drop of Acid Demand (R-0005) the colors are much easier to discern the readings (oranges and yellows). What I'm trying to understand/confirm is how much each drop of Acid Demand lowers the reading. From informal testing it seems that each drop is roughly ~0.2 change. From my current pool test, it looks like my pH is currently between 7.8 and 8.0. If I add 2 drops of Acid Demand the reading is somewhere 7.4-7.6. Is the assumption of ~0.2 change for each drop correct? Or conversely, how can I determine what my pH level is when it tests at the higher range.
FYI, here's my latest tests results, my current targets are in brackets on the right:
Water Temp - 72F
FC: 4.6 (4.0)
CC: 0.0 (0.0)
pH: 7.9 (7.8)
TA: 70 (60)
CH: 300 (300)
CYA: 50 (55)
Salt: 3300 (3000)
CSI: -0.08 (-0.27)
Water Temp - 72F
FC: 4.6 (4.0)
CC: 0.0 (0.0)
pH: 7.9 (7.8)
TA: 70 (60)
CH: 300 (300)
CYA: 50 (55)
Salt: 3300 (3000)
CSI: -0.08 (-0.27)
