Finally got the Taylor sample sizer. I thought it was a waste of money until I used it. It is so nice not having to add a little, pour some out, add a little more, too much…. Seems like an under appreciated tool in the kit if you test a lot.
Of course I do. You need the speed stir sample tubes to use the sizer.Yup, that's on my list of gadgets to get. I'm assuming you already have the Speed Stir device? That, in my opinion is more necessary, but the sample sizer may be a runner up.
Maddie![]()
Specifically, you need the Taylor 9198 vials.You need the speed stir sample tubes to use the sizer.
The link shows a picture for me. It's pretty much what you'd expect:Oh? I have no problem with the vials from the kit... how do these differ? I wish the link showed a picture.
... and if you use only the FAS-DPD test for chlorine testing, you can throw away the test kit's little bottle of R-0600 to free up a perfectly-sized hole for storing the SampleSizer.Seems like an under appreciated tool in the kit if you test a lot.
Right. The SampleSizer does the same thing; it's just quicker:I always fill the vial so that the concave meniscus line is on the 10cc. Works okay for me? I'm gonna have to get out my liberated syringe and test that.
I just scoop the water out of the pool and drop the sample sizer in right away to spill the excess back in the pool.Right. The SampleSizer does the same thing; it's just quicker:
Without the SampleSizer, you raise the vial to your eye level (or lower your eye to it), hold it level, and carefully squeeze water into it until the meniscus reaches the 10ml or 25ml line.
With the SampleSizer, you just fill the vial to anywhere above 10ml, stand over a sink and drop the SampleSizer into the vial, then remove the SampleSizer. To get a 25ml sample instead, you fill to anywhere above 25ml and flip the SampleSizer upside down before dropping it in.
Any reason to use one for chlorine only?The link shows a picture for me. It's pretty much what you'd expect:
The Taylor 9198 and the tftestkits non-chlorine vial are the same size, I think. But the "chlorine-only" vial from tftestkits is a different shape; if you use it, the SampleSizer won't displace the right amount of water and you'll end up with the wrong sample size. I replaced both tftestkits vials with 9198s (and wrote "chlorine only" with a Sharpie on one) to be sure.
I've heard that the DPD powder eventually stains the vial, although I haven't seen that (maybe because I only use one dipper of powder per test, so it dissolves completely). The staining can apparently be removed with rubbing alcohol, so it's not a huge deal either way.Any reason to use one for chlorine only?
Here's a silly thought:I swear the water level is the same both ways. Everything else is exactly the same (e.g. the speed-stir). But the sample sizer test is still about 1.5 ppm lower every time.
I haven't.I'm wondering if anyone else has had this strange experience.
I have not noticed that. I even tested back to back with and without the sizer when I first got it just to see if it made a difference on what I thought was 10mlI got a sample sizer and love it in concept.
But this really weird thing happens. I consistently get lower FC readings than when I manually tweak the level to the 10ml mark.
I've done hundreds of tests measuring manually. No problems with consistency. I swear the water level is the same both ways. Everything else is exactly the same (e.g. the speed-stir). But the sample sizer test is still about 1.5 ppm lower every time. Crazy!
When I first got it, the difference was 3ppm. I've let it soak in the pool for days, scrubbed it several times with soap and water and then with isopropyl alcohol to get it to this point.
I'm thinking maybe there's some residual left over from the aluminum coating process that poisoning the reaction. But that's entirely a guess.
I noticed the pill scratching the tube more than anything. I have 2 only because I found one in the street when I was walking my dog. I thought I recognized it, picked it up and sure enough, a Taylor tube. Some pool guy probably wasn’t too happy.I've heard that the DPD powder eventually stains the vial, although I haven't seen that (maybe because I only use one dipper of powder per test, so it dissolves completely). The staining can apparently be removed with rubbing alcohol, so it's not a huge deal either way.
