Taylor sample sizer. Unnecessary and love it
DrewLG
193
Santa Cruz Mountains, CA
Oh? I have no problem with the vials from the kit... how do these differ? I wish the link showed a picture.
The link shows a picture for me. It's pretty much what you'd expect:
The Taylor 9198 and the tftestkits non-chlorine vial are the same size, I think. But the "chlorine-only" vial from tftestkits is a different shape; if you use it, the SampleSizer won't displace the right amount of water and you'll end up with the wrong sample size. I replaced both tftestkits vials with 9198s (and wrote "chlorine only" with a Sharpie on one) to be sure.
Reactions: Stump and KJB1
DrewLG
193
I always fill the vial so that the concave meniscus line is on the 10cc. Works okay for me? I'm gonna have to get out my liberated syringe and test that.
Right. The SampleSizer does the same thing; it's just quicker:
Without the SampleSizer, you raise the vial to your eye level (or lower your eye to it), hold it level, and carefully squeeze water into it until the meniscus reaches the 10ml or 25ml line.
With the SampleSizer, you just fill the vial to anywhere above 10ml, stand over a sink and drop the SampleSizer into the vial, then remove the SampleSizer. To get a 25ml sample instead, you fill to anywhere above 25ml and flip the SampleSizer upside down before dropping it in.
KJB1
186
Temecula, CA
I just scoop the water out of the pool and drop the sample sizer in right away to spill the excess back in the pool.
KJB1
186
Temecula, CA
Any reason to use one for chlorine only?
DrewLG
193
I've heard that the DPD powder eventually stains the vial, although I haven't seen that (maybe because I only use one dipper of powder per test, so it dissolves completely). The staining can apparently be removed with rubbing alcohol, so it's not a huge deal either way.
Reactions: YippeeSkippy
proavia
3,598
Chandler AZ
CircuPool RJ-45 Plus
I picked up a 10ml syringe (normally used to administer kids medicine) for well under $5.
Works great. Amazon has them for less than $3 or a five pack for $9.
Cheaper and less messy too.
Reactions: HermanTX
Newdude
17,140
NY
CYA squirter bottle. It's just sitting there bored 9.5 times out of 10.
I appreciate the sample sizer and everyone who likes it. For me, I make enough mess as it is without spilling water on purpose. :crazy:
  • Haha
Reactions: proavia
generessler
273
Chapel Hill, North Carolina
Jandy Aquapure 1400
I got a sample sizer and love it in concept.
But this really weird thing happens. I consistently get lower FC readings than when I manually tweak the level to the 10ml mark.
I've done hundreds of tests measuring manually. No problems with consistency. I swear the water level is the same both ways. Everything else is exactly the same (e.g. the speed-stir). But the sample sizer test is still about 1.5 ppm lower every time. Crazy!
When I first got it, the difference was 3ppm. I've let it soak in the pool for days, scrubbed it several times with soap and water and then with isopropyl alcohol to get it to this point.
I'm wondering if anyone else has had this strange experience.
I'm thinking maybe there's some residual left over from the aluminum coating process that poisoning the reaction. But that's entirely a guess.
  • Wow
Reactions: KJB1
DrewLG
193
Here's a silly thought:
The Taylor 9198 vials have both a 10ml line and an 11.5ml line. Are you SURE that you're filling to the 10ml line when you test without the SampleSizer?
I haven't.
What happens when you do the FC test with a 25ml sample?
KJB1
186
Temecula, CA
I have not noticed that. I even tested back to back with and without the sizer when I first got it just to see if it made a difference on what I thought was 10ml
KJB1
186
Temecula, CA
I noticed the pill scratching the tube more than anything. I have 2 only because I found one in the street when I was walking my dog. I thought I recognized it, picked it up and sure enough, a Taylor tube. Some pool guy probably wasn’t too happy.
