Is the stuff called "TAYLOR TECHNOLOGIES INC R-0013-E CYANURIC ACID" actually the CYA or is it just the stuff you test with… or both? I couldn't figure out if the reagent is just liquid CYA for sure.
It's just the stuff you test with.
You are spot on with a FC of 5! It is fine up to 28! So you are FINE! LOL Some people have to add a little more depending on their pool and environment (full sun, H.O.T. temps. big swimmer load, ect). Have you done a FC test at the end of the day? That is what I use to go by to know if I have my FC high enough. Does it last through the day without going below my min.?
How does your water look? Does it sparkle like a jewel with the sun shines on it and the sun is shining?
Yeah Patience on the TA. It is a small step at a time thing. TA is the last thing we work on so you are doing fine.
A whole week??? SWEET!
Kim![]()
Has all of the CYA dissolved? How much did you have and what was your goal when you added it?
The CYA test has a +/- of 15 so if you did not add very much it could be that. When you do the test make sure to just GLANCE in the tube. Do not stare.
Kim![]()
Well that does help! Good check and recheck! You have really learned a lot in a short time!
It will be interesting what happens when the cover is off!
Kim![]()
LOL I went back to read your first post after reading this one..............You have come a long way sweetie!!! It is so neat to see you say "failed OCLT but I will probably do that again at some point" just like a seasoned pool owner!
I hope you start reading other people's threads and start jumping in to help as you can. Just reading what is going on with others will help you if something happens in your pool.
Kim![]()
