Hello all,
New spa owner here. Got an Intex inflatable "6 person" spa with bubble massage. I've read and am following the How do I use Chlorine in my Spa (or Pool). I haven't yet added dichlor, I'm still working on the acid and aeration portion of the guide.
Got the tub inflated Thursday and partially filled. Finished filling Friday morning with some hot water and started testing and balancing. Testing with Taylor K-2006 test kit. All aeration periods 1/2 hour as that was the auto-off length on the bubbles. oz are weight, not fl oz, weighed with a small scale.
Initial Testing:
Friday:
Today:
The guide implied that once you get to ~50 ppm TA, aeration would bring your pH up to ~7.6 and it wouldn't go higher. I'm almost there, and the pH is still at 8.0 or higher after aeration. I just don't want to overshoot, wanted to make sure I'm not missing anything before I add more acid. Do I need to let it sit longer between testing? For many of the tests, I would add acid, aerate, then test almost as soon as the 30 minute aeration was done.
So, my main question is: Should I continue adding a little acid to drop the TA to 50, or should I start adding borates and dichlor, adjusting pH as needed going forward? Or am I missing something here?
Initial Testing:
- Calcium hardness: 250 ppm (might have miscounted one or two drops)
- Total alkalinity: 275 ppm
- pH: 7.3. 3 drops acid demand dropped it to 7.0
- 290 gallons, according to Intex
Friday:
- Aeration. pH now at 8.0 (max reading). Acid demand was 8 drops to 7.2, or roughly 2.5 oz 31% MA according to tables and conversion.
- Added 2.4 oz MA.
- After 1/2 hour without aeration, pH was at 7.3
- Aeration. pH now 8.0
- TA now 175-200 ppm, though I think I miscounted drops.
- Added 2.5 oz MA, aeration.
- pH 8.0. 6 drops acid test to 7.2.
- pH at 8.0. TA at 175 ppm (this time I know I didn't miscount)
- Added 3.0 oz MA, aeration.
- pH at 8.0.
- Added 3.1 oz MA, aeration.
- TA now at 125 ppm.
- Added 3.2 oz MA, aeration.
- Water temp at this point was 75 ****°F, I covered it and went to bed.
Today:
- Water temp at 88 °F. pH was 7.8 before aeration. One drop acid demand took it to 7.4, 2 drops down to 7.0. TA was at 70 ppm, this time I used the fine measurement (10 ppm/drop)
- Added 0.6 oz MA, aeration
- pH at 8.0. TA at 60 ppm.
- Added 0.8 oz MA, aeration.
- pH at 8.0. TA at 60 ppm (Colorless at 5th drop, red on 6th)
- Covered and let sit, came here to post. Water temp at 83 °F when I left it.
