- Feb 6, 2015
- 7,809
- Plaster
- CircuPool RJ-45 Plus
Put one on the board and the other on the post or back side of the board.I'm thinking that, if I go CORE, I could probably get this done a bit quicker by skipping the utility panel upgrade. I suspect I have enough blank space on that hunk of mahogany to mount a T-104 or an RJ controller, but not timer and controller. Controller would stick up past the top of the panel a good bit, but mounting brackets appear to be further down on the box, so I could probably get it on there. Back side of my mounting panel has even less space, due to post, and fence obscures access.
Core takes up more space down on the pad, but if I'm getting rid of the Frog and some surrounding plumbing, that may be less an issue. Long way of saying, for my situation, CORE may have some advantages over RJ. Anyone here have a CORE, who can chime in on it?
The CORE is not as adjustable as the RJ series.
