- Jun 24, 2021
- 15,884
- Vinyl
- CircuPool RJ-60 Plus
You need to look at the output for the period of time. The 20% for 4 hours will put .5FC in the pool.Since this thing has the ability to keep pool chlorinated at a setting of just 5% to 15%, bumping it to just 20% represents a full doubling of my average rate.
My pool, 30K, with cover, 90 CYA will run 24/7 at 5-10% and has 1FC demand with no use.
Sunny day in July, I pull the cover and have many swimmers, my FC demand is 3.5-4.5. With lower CYA can get to 5.5FC demand. I turn the SWCG up to 50-70% when cover comes off, and back to 10% when cover goes on, or sometimes I wait until 8pm if cover goes on at 5-6. This typically handles any demand and leaves my FC close to starting FC.
If you turn your cell up to 50%, and run it for 8 hours, it will add 2.7FC. I would suggest that you try 50% running during the day/party. Better to be on the high side and avoid mins. If it is too much, raise it to 40% next time.
It is likely that that 20% is not enough, and your FC will fall.
