Hey guys. We're going to be draining and refilling our pool in the coming weeks. It is being done to repair the quartz, but it works out perfectly as the CYA is out of control due to using trichlor for two seasons (I now know better). I have a few questions on the matter.
1. Draining: My thought process is to let the chlorine drop over the last couple days so that the water getting drained is fairly unchlorinated. If I drain water onto my lawn with low chlorine and neutral-ish pH, will there be any problem? Is there a pH I should target?
2. Startup Chemistry: Is there anything I need to consider when starting up besides the standard Chlorine, pH, CYA, and Alkalinity? Is there a reason that any of these should be higher or lower than normal at the start? Or any specific order that I should address these in?
3. CYA Approach: Should I get standalone cyanuric acid and dump it in? Or should I just use trichlor tabs initially to raise the CYA levels? Oh, and what level should I initially aim for?
4. Gotchas: Anything I should know that I am missing? We've only had a pool for 1.5 years and never drained/refilled it. Is there anything I need to know that I haven't mentioned? Thanks!
