I'd target 7ppm instead of 6. Especially if you still have sun on the pool. If you add chlorine at night (dark) to your target level, it should last you throughout the next day assuming no extra swimmer load. You'll have to test a little on the regular at first to see what you lose vs swimmers vs sun only to know how much you'll need to add per day and your particular variables.
Don't worry about having too much FC. You're actually safe to swim up to SLAM level for your CYA level. It never hurts to err on the high side.
I'm a little concerned about the 4.4oz recommendation. Do you have your pool volume set up? 4.4oz seems low to add 2ppm with your size pool. If you back out of the adding page on the app and re-enter it, check the pool volume and CYA level, does it still say 4.4 oz?
