So on my first post ever I posted my concerns over the new pool water. Having never done any testing myself (always took it to pool store) I was advised to get a kit and do it myself. One of the kits suggested was the Taylor K2006C. I accidentally ordered the Taylor K2006...grrrr.
Here are the results as well as the process I took to do the test. Bear in mind this is the first pool water test I have ever conducted. If you see any mistakes in the process please let me k ow but I believe I followed the instructions well.
Free and Combined Chlorine Test (I am assuming this is the FC on the PoolMath App - Filled comparator tube to 25mL l, added 2 dippers of R-0870, swirled until dissolved. Instructions stated if free chlorine is present sample would turn pink, it did not.
TA - Filled comparator tube to 25mL and added 2 drops of T-007, swirled, added 5 drops of R-008, sample turned green, added 1 drop at a time of R-009 until sample turned red. Sample turned PINK after drop 14, times 10 = 1400.
PH - Filled comparator tube to 44mL. Added 5 drops of R-0004. Mixed. Looked like the most pink square on the tube, assuming 8.0, see picture.
CH 16 Filled comparator to to 25mL. Added 20 drops of R-0010. Swirled. Added 5 drops of R-0011L. Swirled. Sample turned red. Added 1 drop at a time of R-0012 swirling and counting after each drop. Sample turned blue after drop16. Times 10 = 160.
CYA - Filled small bottle to 7mL and added R-0013 to to 14mL mark. Mixed for 30 seconds. Transfered solution to CYA section of comparator slowly, looking to see at which point I could not see black dot. I could still see drop at top level (30).
Thanks for the help guys. Any advice of how to proceed is appreciated. I will plug these numbers into the PoolMath app and see what I get.
Also this is what the water looks like, clear and blue. No cloudiness or green at all.
Rod
