I have a 10K pool in Houston, TX. The backyard has many trees, so I get a lot of leaves and lots of sun, too. It’s all Pentair equipment, and the filter pump is an intelliflow. I load a Stenner pump monthly with 12% bleach and struggled quite a bit to control algae before this setup. The problem is sourcing bleach and the price ($3.5 / gal). I have to drive an hour to pick up the bleach. I am caving, planning to bite the bullet, and installing an SWG. The local installer recommended IC40 ($3.2K). Should I go for an IC60 instead? In the dead heat of summer, I need about seven gals of 12% bleach per month to keep the pool from turning green.
Did any of you convert your bleach delivery to an acid-dosing system? Thank you in advance.
