Here is the link. . Looks like in my update, it was lost on the 1st post. . I will update it later when I get back to my computer. .
Dropbox - SWGCalculator.xlsx
Your welcomeI can't believe I just found this. This is awesome. Thank you very much for taking the time to create it.
I see you have a new pool, new SWG and many different threads with lots of different questions. Did you ever get the CYA test finalized? If so, what are those results?I need to figure out what is going on because my generator should be able to keep up with the chlorine loss at 75% for only 4.5hrs but I have been running it at 8hrs on low and it is not holding it. Is this assuming pump running on high or does that not matter?
Just a thought, but sometimes the SWG will not generate chlorine if the flow is not high enough. Not sure if this would be the problem in your case though.I need to figure out what is going on because my generator should be able to keep up with the chlorine loss at 75% for only 4.5hrs but I have been running it at 8hrs on low and it is not holding it. Is this assuming pump running on high or does that not matter?
Great, thanks.
Here is the latest. Anything that I am missing? Obviously, the most difficult part is the PPM loss. I would think this could be measured over several days or a week and average it out. This would have to be done without the SWG running. Even that might not be right since there are alot of factors but it should be a decent starting point. Otherwise, maybe start with a value on the high side such as 3 or 4 and then back down from there.
If you want to download and take a look, here is the link: https://www.dropbox.com/s/xbrx61honuuu3jm/SWGCalculator.xlsx?dl=1
The link that you quoted worked for me.Is there a working link to this tool?
Then you must need less FC ppm than you thought per day. Not the charts fault.I found that chart not very close for my pool. Chart said 12 hours 60%. My chlorine was climbing daily. I'm down to 8 hours at 35%
