Opened the pool on Monday and have been battling low chlorine levels. Last year was the first year having the pool and after some trial and error, I found that running my SWG at 40% production for the 16 hour pump cycle (@1800 rpm) kept me around 5-6 ppm. Since opening, I have had my SWG running at 100% and can't get chlorine level above 4 ppm. Not sure if it means anything but I also noticed the typical tiny bubbles I usually see coming out of the returns were not present. I had a local pool service close my pool last year and open this year since it was my first close/open. They take the electrolytic cell to the shop for cleaning and then return at open. I figured I would try cleaning again to see if that would help. Upon removing the cell, i found what looks like white melted plastic. I tried using the recommended 10:1 water:muriatic acid solution soak for 5 minutes but this stuff didn't budge. Anyone ever see this? Is this calcium deposits? I chipped off a piece and put it in a cup with straight acid and nothing happened. I'm lost.
