- Nov 8, 2023
- 34
- Plaster
- Jandy Truclear / Ei
Per the suggestions of many on this forum, we are converting our pool to salt water. Already had a new Gulf Stream heater installed last week, and having a SWG, pump, filter, and automation installed as I write this post. So what do I need to do first, test the water for salt level, then figure out how much salt to add to start off? What should a person look for when buying bags of salt? What brands/stores do you pros recommend? To start off I will probably just have the local pool supply store test my water, but eventually I'd like to do the testing myself, so I need to learn what to buy in order to perform water testing.
