Why aren't you using the Trouble Free Pool's PoolMath app instead of that *other* one?
I am curious, where did you find the data for all the things you listed in your 2nd paragraph? None of them here on TFP.
A SWCG replaces having to add chlorine every day. You may have to add some acid every once in a while, but you had to do that before if using liquid chlorine exclusively.
Many also find the water to be much more refreshing. But that is up to each individual person.
Dang.. Marty posted first.. now I have to say something different....Ok, well since I've been thoroughly convinced to go on with the SWG installation, I've also read that water temp should be at least 70 degrees before installing, is this true?
Any other tips on install I should know about or be wary of?
Thanks for all the info!
Rich
