- Apr 3, 2025
- 54
- Plaster
- Hayward Aqua Rite (T-15)
Hi all,
Previous non-SWG pool experience but this will be my first time with a SWG. We're due to add salt next weekend as we pass the 28-day curing mark.
While reading up in the FAQs and forums, noticed a small number of posts discussing what was believed to be SWG or pipe explosions attributed to chlorine and/or hydrogen gas buildup. I'm using a Hayward OmniLogic system with a TCELLS340. While I don't see an interlock option for the SWG and main pump, I'd like to believe the automation software won't energize SWG without pump on (and flow switch closed). Accurate?
Also, since the concern seems to be a buildup or collection of combustible gasses in the system, wondering if I need to remove my chlorine tablet feeder. I notice that it's after the flow switch and SWG, so--if gases can buildup and this reportedly can cause an explosion if an ignition source occurs--then would the tablet feeder be ideally positioned to collect and build those gases up over time? I can turn off the water flow but I believe this simply takes away water from flowing over the tabs. Don't know if it would disconnect the stack from the flow below it. Don't think it does.
Should I remove the stack feeder?
