- Nov 15, 2019
- 49
- Plaster
- Pentair Intellichlor IC-60
I have Pentair automation easy touch. Starting with the IC40 at minimum. 16,500 gal in ground plaster.
I have few questions of course and any other insights you can offer.
1. My initial thought is removing the inline chlorinator which i don't use anyway. That is only 20 inches from behind the check valve to the other end. Is that enough room? The Automated valve behind that is the spa fyi.
2. The other option is the heater return and that has a little over 21 inches and it's only 11 inches from the heater sidewall.
3. I don't have the transformer in my easy touch so I will need the external transformer. Are there any other items, other than pvc, cell, and transformer needed.
Thanks for the start of my journey to SWG.
