What about last year ? Was bleach used instead of chlorinating liquid or liquid shock ?only put in Calcium, acid and salt
Not that I am aware of . But could be possible. If so what would I doWhat about last year ? Was bleach used instead of chlorinating liquid or liquid shock ?
I just turn the Swg offBleek,
Very odd indeed!!!
With a Salt level of only 1100, your cell should not even be working at all...
Your bubbles look a lot like soap bubbles.. They do not look like SWCG bubbles.
So tell me what you do to turn off the SWCG? Are you just shutting off the pump or what?
Ok thanksDid you add any pool store chemicals in the time since you opened your pool?
It looks very cloudy. You need to add 5 ppm liquid chlorine then let it mix and using one of the recommended test kits, either the TF-100 from tftestkits.net or the Taylor K-2006C test the water to see if the FC is holding.
Your SWG can not raise your chlorine level fast enough, it is used to maintain the FC level. Add liquid chlorine and see if It holds. If it hold then you need to raise CYA level.
The polymers would need chlorine to break down. So basically it will work itself out as the SWG produces chlorine, if that's the cause.Not that I am aware of . But could be possible. If so what would I do
Yes. First time I have to do it myself.Did you say this is the first year you’ve started taking care of the pool?
Do I need to keep running the SWG while I wait for it to subside? I hate the foam. I am trying to get my house on the market to sell. Can I just run the pump and keep the chlorine level up?There have been cases reported that in pools that are opened in the cold area of the country can see lots of fine hydrogen bubbles from the SWCG when it is first started. It will subside.
Or, you added something like an algaecide. Again, it will subside.
SWG causing foam on pool.
I installed a new salt water generator this year. Now if it’s running my pool fills with foam. If I turn it off, foam disappears. I am still working on balancing the pool. Any thought?www.troublefreepool.com
I would use liquid chlorine and maintain SLAM level FC to clear the foam.Do I need to keep running the SWG while I wait for it to subside? I hate the foam. I am trying to get my house on the market to sell. Can I just run the pump and keep the chlorine level up?
