My pool has two skimmers. The returns from these terminate in a Jandy valve, from which a single pipe enters the pump. When I rotate the valve to the center position, there's an air leak that can't be primed out. However, if I turn the valve to the left or right (20 degrees or so), the air leak stops and the pump will prime completely. I suspect Jandy valve has a bad O-ring or needs to be rebuilt. Any suggestions? I appreciate your input.
