I have a 13,000 gallon chlorine in-ground pool built in 2005. All original equipment except for pump which was replace a few years ago.
I noticed that my pool cleaner wasn't moving, so I did the following troubleshooting.
1. Had the filter cleaned and that did not resolve the problem.
2. Replaced the cleaner as it had many miles on it, so I bought a new one. Before I installed the new one, I tested the suction with the device they provide and the level was below MIN. I plugged the hose into the suction port anyway and the cleaner did not move. I shut down the skimmer valves and there is minimal slow movement.
3. Checked the impeller in the pump by sticking my fingers in there and didn't feel any clogs.
4. Inspected the equipment pad and don't see any leaks or drippings
5. Pump is running at full prime with just a few air bubbles near the lid which has always been the case
I also had my water features turned down, so I tested them out and they don't have the power that they used to - this applies to all the fountains at each end and along the sides. So it seems like pressure is low throughout.
Any suggestions on trouble shooting as I really don't want to have my year dug up if it's not necessary?
