~8000 gal SWG inground pool. Hayward DE filter. Passive solar heating.....This is my 5th season with the pool.
I just installed a new T-Cell. Leslie's said that my chlorine was a bit low, so I tossed a puck into the skimmer. For the first few days, the pool was crystal clear though it did have a very slight trace of algae along one side. I brushed it off hoping that between the new Cell and the puck I'd get it licked.
It did initially, but now the pool has an ever so slight, cloudy appearance. To add to the mess, I put in some "Austins Pool Tech algaecide" which is Dimethyl benzyl ammonium chloride - 4.98% and Dialkyl methyl benzyl ammonium chloride 0.02%.
Now 24 hours later the pool is still cloudy and has a slight film of suds. It's not an enormous amount, but I've never had suds before. Boy, can I screw up a good thing or what??
Leslies' tells me that my chemistry is Dang near perfect and only recommended adding Phosfree or some other chem to lower the Phosphate level. They said that I had a high level of organics in the pool and that my neighbors' trees might be the culprit. My neighbor has a huge river birch that pukes a million little doo-dads into my pool each spring. It takes that tree about a week or two to rid itself of its quinoa and refrain from soiling my pool. And since all of their stuff is usually hideously marked up, I passed on that.
1. Should I be concerned about this and if so, is there a decent product (cheap) to lower phosphates?
2. Was the algaecide a bad idea?
3. Will the suds eventually go away or do I need to add something to offset the effect of the algaecide?
