In Florida. Saltwater 10k gallon pool with Pebble Tech, no screen and a few trees and leaves to contend with. I was having slight algae issues back in the summer despite what I thought was balanced water and thus beefed up my chlorine. I had read here that with saltwater pools the chlorine should be a little higher than the recommendations. So I did that and the problem went away, water has been clear and clean. Well, now that it has been cooler in the past few months I turned down my SWG pretty low because I figured I didn't need as much chlorine with colder water, and everything has been fine. Just been adding muriatic acid when needed. But my chlorine has gotten up super high and stayed there. I went to Leslie's for a water test and here's what I'm looking at:
Free Chlorine: 14.07 (Rec. 1-4)
Total Chlorine: 14.42 (Rec within 0.2 of FC)
pH: 7.7 (7.2-7.8)
Total Alkalinity: 56 (80-120)
Calcium Hardness: 246 (200-400)
Cyanuric Acid: 43 (50-100)
Iron: 0 (0-0.2)
Copper: 0.2 (0-0.2)
Phosphates: 389
Salt: 3000
There's a slight chlorine smell when you're actually in the water, but nothing unusual. No burning eyes or anything. I turned SWG all the way down to like 2%. How big of an issue is this if at all?
pH: 7.7 (7.2-7.8)
Iron: 0 (0-0.2)
Copper: 0.2 (0-0.2)
Phosphates: 389
Salt: 3000
