- May 3, 2014
- 62,698
- Fiberglass
- Pentair Intellichlor IC-40
Possible.
But I suspect your TA is not that high. Are you following "Sometimes a static electric charge can build up on the R-0009 dropper bottle tip, causing the drops to be smaller than usual and making the test read higher than actual. You can prevent this by wiping the tip of the dropper bottle with a damp cloth or tissue before you start and after each drop."
