OK! We have water and the pool looks good. Very inviting -- too bad we've been told to stay out for 5 days (til next Tuesday).
A couple issues:
1) when the solar is on, the pump needs to be at mac 3400 RPM for 50 gpm. We only have 470 sq ft of panels.... is this normal? It'd be cheaper to use gas to heat the pool if I have to be at 2800 Watts for 6-8 hours a day to heat the pool with solar!
2) the setup guy had not heard of using a dummy insert for the SWG for the first 30 days. I showed him the place in the manual where it requires this, but there really is not choice but to run it with the cell as he doe snot have the dummy cell. He intends to acid clean it after 30 days -- what will this do to the life of the cell?
3) this is the Biggie: I'll need some hydraulics experts for this one. The schematic (abbreviater version below with unrelated equipment eliminated for clarity) shows the spa bypass to get more flow around the filter while in spa mode to lessen the pressure on the filter, lower the power usage and increase the spa jets. The check valve right after the heater closes in this mode and no water gets through unless the bypass is almost all of the way turned off.
At first I thought -- Of course, there is more pressure in the bypass than from the heater, so it'll shot that check-valve. Why is that valve there anway? To prevent flow bacl throught the filter.... but how could this happen? Yes, it seems there would be more pressure in the bypass, but to make the filter flow backwards (I want to avoid this) it would have to push back against the pump though the bypass valve -- that's higher pressure.... it should not happen..... but for the same reasons the check valve should not close either....
(interestingly if the bypass is urned on 100%, the pressure in the filter stays high, as it is 'locked' in from the check valve and the bypass valve. It lowers if the relieve valve lets the pressure out.)
I need the call out he experts! (thanks in advance).
