Remember that the pressure you see on your filter gauge is the pressure between your pump, and the filter media, not the pressure coming out of the filter. That pressure is considerably less than you see on the gauge... almost non existent, as there is nothing to create a restriction beyond that point to drive the pressure up. Even a 10psi pump would probably work if your injection point is between your pump output, and the pool.
