Hi, I bought a Stenner injection system for my well water system. The Stenner system injects Hydrogen Peroxide into the water flow. When I first got the system it worked fine without any issue. Its been about 4-months and I noticed that the system was not pumping. The flow indicator was not showing any flow when the pump was operating. I noticed the pump was not keeping a prime. So I replaced both the rollers and tubing on the pump, and the injector (thinking that it might have been clogged but it wasn't). I am still having the same problem with the pump not priming and not pumping strong (i.e. flow indictor ball barely moves). I inspected the suction tubing, strainer, and discharge tubing and could not find any issue.
Has anyone had this issue? If so, what did you do to correct?
