- Jul 3, 2019
- 4
- Plaster
- Pentair Intellichlor IC-40
We are embarking on a large backyard/pool renovation and are grateful for any insights into what we should consider (what we are missing) or tips for success (what you learned that made your project go smoothly).
Thank you for all the great information that is shared on this forum and everyone’s willingness to help.
KC
PS. I attached a photo (please excuse the leaves in the pool bad storm overnight)
What we currently have
- 33,000 in-ground plaster saltwater pool with attached spa (20 years old)
- Original poured concrete pool deck with cement safety coping (curved up)
- Equipment pad Pentair equipment (3–7 years old)
- SWG: Intellichlor IC-40 (3 years old)
- Pump: Superflo VS (6 or 7 years old)
- Filter: DE FNS Plus 48 (6 or 7 years old)
- Heater: MasterTemp 300 (5 years old)
- Cleaner: Polaris 3900 and Polaris booster pump
The background (ie what started this massive snowball)
The tile on the spillway began to fall off and the tile at the waterline is original (think 1980’s kitchen backsplash) so we wanted to get new coping and tile. It turns out the pool deck is lifting and cracking in some areas. The retaining wall is beginning to fail, and the stone wall on the other side of the pool is also failing. So what began as a few tiles fell off is a complete redo of the backyard. We know it will be nice and are excited about it.The scope of work
Complete demolition and new drainage system, new retaining walls and steps, new fence, new larger pool deck and patio using pavers, and pool renovations.The pool renovation includes
- Replace the main drain with Virginia Graeme Baker compliant drain
- Repair spillway wall
- New paver coping and ceramic waterline tile
- New skimmers
- New Pentair Intellibright white LED pool lights
- We are going with a PebbleSheen (slate blue) finish
Questions
- We do not have a pool automation system - is it worth it? Any added benefit in doing it during all the other work?
- Is there anything else we should consider while the pool is having all this work done?
- Are the Intellibright lights worth it? Would you go with color instead of white?
- Feedback on PebbleSheen, is it worth it? Does anyone have Slate Blue or a color they really like?
- What are we missing?
- What do you wish you did/included when taking on a project like this?
- Is it a mistake to get rid of the diving board?
KC
