MeSwamp
12
Pleasanton, CA
Hello! Brand new here :)
Like many other newbs, I let my pool go over the winter (sorry). I am currently on week two of my SLAM and the water is looking soooo much better; however, now that I can see better I have discovered that many of the walls are stained….
I am on well water, but I haven’t had to add any water to the pool since November. Could it be iron, or is it mustard algae? It doesn’t brush off, even when I put my weight into it.
Start reading here first. This will give you an idea of what different stains look like and how to treat them.
Ah this is great, thank you!
Ah ok, good advice thank you. Is there a kit in particular I should get? I just looked and saw one from Jack’s Magic, do you know if that one would be ok?
Being a newb, like me, you might miss some issues (I totally focused on rust staining not realizing that I also have calcium precipitation that also bubbles when scrubbed with Vit C tablet). Thence my suggestion to get a kit.
Pinch-a-Penny kit is similar to Jack's Magic kit, so I'd get whichever is cheaper.
And yes, do read entire stain guide here to get theoretical background for the process.
Reactions: MeSwamp
Thanks! I keep reading more and getting convinced I have every problem 😅 Iron? Omg for sure. Copper? Whoa ya maybe that too. Mustard algae? Probably definitely. Going down the rabbit hole of pool problems and I just need to take things one step at a time haha! I like cheap when possible, so I’ll check out pricing and get test kit so I can hone in on my issue after slam is complete. I really appreciate your help!
Ok my SLAM went well, pool water is totally clear and beautiful, passed all the criteria for completion annnnnnd the stains are still there… I even SLAMed for mustard algae just in case and it made no difference in the stains.
I tried rubbing a chlorine tab and vitamin c tab on one of the stains and didn’t notice any difference in the stain. There is definitely scale, I dripped some acid on and it bubbled up immediately. So scale is obviously one issue, but what about the stains? They are mostly along the walls, seems they are worst in the shady areas.
I will attach a few photos for reference.
What should be my next course of action?
Until the other guys get back with more guidance can you share all your latest test results?
Fc
Cc
Ph
Ta
Ch
Cya
water temp
How old is the plaster?
Lots of it looks like worn plaster.
For the scale:
Pool companies will use an acid wash to get rid of the scale and some of your plaster which we don't recommend.
You can pumice or sand the pool surfaces to remove the scale.
You can try and run your CSI very negative at -0.6 to -0.8 and see if the scale melts off in a few months.
We had a recent thread about scale in a commercial pool at...
For the scale:
Thanks I will study up on this!
Reactions: Mdragger88
If using
PoolMath
(which we recommend)
Be sure to turn on csi tracking in the settings ⚙️
Your ch is getting up there-
Do you know your fill water ch?
Just tested it:
Ch 250
We are on well water and it is hard, had scale buildup on faucets inside the house before, but we use a water softener now.
The pool used to be filled using the hard water, so that’s likely why it’s on the upper end for Ch. I was honestly surprised that is wasn’t higher… Anyway, we shouldn’t have a problem with increasing the Ch with the fill water anymore right?
Thanks for the calculator! I will use it to have a slightly negative csi and hopefully melt off some of the scale over time. The stains in the scale are so ugly and extensive! Is there a particular metal that likes to hang out on scale? I guess the stains will go away with the scale so that should be my focus.
So is the fill water from the softener?
Wells are a common source for metals, namely iron.
Focus on dissolving the scale for now.
250 ch is still pretty high for fill water & will cause ch to continue to rise overtime as you replace water due to evaporation.
(When water evaporates the calcium remains in the water then you add more ch rich water)
You may want to consider a partial water exchange to lower the ch in the near future to help make maintaining the lower csi easier.
