Stainless Steel pool?
Hardrock AC just put one in the SPA. Had to take down / move duct on the floor below so new steel could be put in for it. Stainless shell, not sure if there is a liner in it.
I figure out how to run the duct and I am never there when it's all pretty.
Maybe I’ll stay there when I go to Pool convention in January. We usually throw a private welcome party at harrahs pool, but it was being renovated last year.. karma!
Harrah's pool is much larger and a larger area surrounding it.
The pool in the spa is not as big. Home now or i could look at a background drawing to get the size on the pool in the spa. Steam and sauna rooms in both men and womens areas.
Oceans resort has the indoor/outdoor rooftop pool on the ocean side.
316L SS tolerates typical chlorine levels just fine. The issue can be found at the water line. Epoxied on tile solves this O2/chlorine/stainless reaction. Every notice your SS ladder will develop rust on the undersides? Sure it cleans off easy, but if you rinsed it off with fresh water after use, it would never rust. That and most ladders are constructed out of cheaper 304 causes this. I'm learning these pools are fully welded and self supporting. Word is, they consume less chemicals than a gunite pool and many last 70+ years with no repairs. However if you can stomach the high initial cost, you probably don't care about saving $100 bucks a month on chemicals and you won't live another 70years anyways :rolleyes: Salt is possible, but not recommended. For those wondering, I'm being told most build them out of 12ga for the floors and some go as light as 16ga for the walls. They use a mixture of MIG and TIG and are completely welded vessels. Interesting stuff, expensive, but still interesting.
I think you'll find Bradford has done 90% of the pools in Vegas. I'm kinda surprised none of you own one of these beauties....?:confused:
Ain't no way I could get in there without being tethered to a palm tree!
It is pretty wild. It is set back a bit as there is a catch basin so if you look over the infinity edge it does not go straight down to the street!
As it is in Singapore, if you do something stupid - well - you did something stupid no one else's fault unlike the USA --
