I see. We'll, you're still relatively new to TFP, so there is a learning curve to pool owner testing & maintenance. We're always happy to assist. Water in our area has been a little chilly (about 60 degrees) which helps to slow algae growth, but that's about to change soon. Having the proper test kit at home is extremely important, not only for convenience to test every day or two, but to ensure "accurate" results as we've learned that many, many pool stores don't provide accurate readings - either from lack of training, poor lighting, or simply being in a hurry.
We recommend the
TF-100 (w/ magnetic speedtor if possible), or the Taylor K-2006C as an alternative. Either of those kits are easy to use at home and provide very dependable results. It's not hard to do, it's just a matter of cutting those cord form the pool store. You'll be glad you did. Let us know if you have any questions.
