Spa water line goes down when pump is off; main pool waterline goes up
cflannagan
123
Palm Harbor, Florida
We have had this issue for about 2 weeks - spa waterline would go down by maybe 6 or so inches while the main pool will go up (by 1/4 inches or so maybe, obviously because of bigger surface area).
This makes me think the 2-way valve (that handles flow from spa drain) might need to be looked at & replaced.
Got in touch with pool repair company; they looked at photos I shared and said they might need to change other valves too, the total job could end up being $1,250. If it's just the check valve, it'd be $195.
I got a bit uneasy during the phone call and wanted to ask for opinions here - sure, it's possible the other valves could have problems too which in that case replacing others would certainly seem justified. But is it relatively common for multiple valves to go bad needing replacement here? Just wanted to hear initial thoughts from others here before I contact the pool repair company again before proceeding with the job. I want to make sure I'm not being taken advantage of (are valve issues visible & clear if I ask them to show it to me?).
Thanks in advance!
(I am working on attaching photos of the pool equipment)
cflannagan
123
Update: I decided to call back and told them to keep the work slot for early next week. Meantime until then, I'm hoping to get a bit more educated on this topic (ie: what common causes are, so I know what to look for while they do the repair job)
Jimrahbe
20,927
Bedford, TX
C,
If your spa drains down to just under the jets and stops, then a bad or dirty check valve is the cause about 95% of the time. That said, I don't see a check valve in your pics.. Show us some pics from the sides of the equipment rather than from the top...
Also keep in mind that if it is an old style check valve they often have to be cut out and replaced, which increases the replacement costs..
It is almost never a standard Jandy valve issue.
cflannagan
123
Sorry, I might have used wrong term and there is no check valve - I added photo with my annotations (I hope "valve" is still the correct term for those parts of pool equipment where I turn the lever?)
The problem is there's a heater in front of the pool equipment, so taking good photo of that side would be tricky. If you still need photos from that angle, I'll take some more (and try my best)
Jimrahbe
20,927
Bedford, TX
C,
If you have a raised spa, that overflows into the pool, then in most cases there is a check valve.. It may not look like a check valve..
cflannagan
123
C,
Yeah it is raised spa overflowing into pool.
Added some more photos for context. The "check valve" wouldn't be that dirty looking orange-ish see-thru bulb-shaped thing in the 1st photo right?
Edit: Ahh the orangish thing in my first photo attached to this comment has "Flo Control" label on it. Searched for it on Amazon, this came up. It's the check valve isn't it? Amazon.com : Flo Control 1720C20 2" Swing Check Valve Union Clear : Swimming Pool Filter Valves : Garden & Outdoor
makes me wonder if I should try replacing that part myself. I have to admit, before talking to you, I didn't think about this from gravity POV.. I keep thinking the 2-way valve that controls the spa drain might be broken inside but now thinking about it from gravity, yeah, with ability to control backflow (due to gravity) broken, I should have looked at that check valve first.
Jimrahbe
20,927
Bedford, TX
C,
Sure looks like a check valve to me.. The good news is that it has unions.. Most I have seen are glued in, making repair a real task.
For $50 bucks, I'd try replacing it myself, before getting a pool maintenance guy involved..
Reactions: cflannagan
cflannagan
123
Update: It was the check valve!
Paid $62 (taxes included) at local pool supply store (didn't want to wait on Amazon, I needed to know if this is the issue before the pool repair company appointment on Monday). Had to also invest into a PVC plier tool (~$16, Home Depot) when I had trouble getting the unions loose to remove the bad check valve. Completed the replacement job.
This morning, checked the spa waterline. It held at the same level overnight!
Money saved: ~$110 (pool repair company quoted me $195 for check valve replacement) Once again Trouble Free Pool helps save us money. Thank you again @Jimrahbe !
Jimrahbe
20,927
Bedford, TX
C,
Just our way of trying to pay you back for being a Gold Supporter.. :mrgreen:
Without supporters like you, this website would not be here..
Glad you were able to get it fixed yourself...
