Spa Spillway glass tile/travertine opinion?
PoolNewbie2022
Active member
Dec 5, 2021
41
San antonio
We are doing a spa spillway into our pool. We were already doing the entire spillway in glass tile, the PB suggested we do the whole entire spillway and spa wall angle facing the pool in the glass tile. We are doing a split faced travertine wrapping around the spa. I Was thinking of incorporating the travertine on the front angle where the full 12x12 sheet of tile is here in the picture.
What are pros and cons of either option of glass tile or travertine on the angle wall? I know it’s personal opinion/preference so If you have a similar set up I would love to see what you decided to go with for your spa/pool. Thanks!
ajw22
41,320
Northern NJ
Pentair Intellichlor IC-60
Calcium buildup and scale on the spillway will be difficult to clean with uneven tile.
The larger the tile and less grout lines the better on a spillway and spa wall. Easier to clean, less grout lines to crack and get water into, and less chance of efflorescence.
Reactions: PoolNewbie2022
PoolNewbie2022
Active member
Dec 5, 2021
41
San antonio
@kimkats can I get your opinion on this please? Everything you recommend turns to gold 😊
  • Love
Reactions: kimkats
ajw22
41,320
Northern NJ
If you are doing glass tile here is the recommended installation buildup by a glass tile supplier.
1626430671428-png.355575
A waterproof coating like Basecrete should be used. Otherwise you can end up with problems like this...
kimkats
52,760
Tallahassee, FL
First off I LOVE, LOVE, LOVE the tile!!!!! Oh the bling it will have will have everyone wearing sunglasses just to look it!
I think the BLING tile should all over the spa front. See both of the flat spots on the "post" on either side of the spa? The one on the deck side and the one facing the pool. I think that BLING tile should be on that AND all down the spa overflow That would really tie everything together and be a MAJOR accent to the pool!
Let me know if you can't "see" what I am thinking.
Kim:kim: aka the BLING QUEEN!
  • Love
Taimon
Active member
Aug 21, 2021
28
Tampa, FL
Jandy Aquapure 1400
It sounds like your PB might be suggesting something very similar to what I have with the entire spa facing the pool and spillway being glass tile.
My personal opinion is the same as .ben and kimkats. Glass all the way and tell your friends and family to bring their sun glasses :cool:
PoolNewbie2022
Active member
Dec 5, 2021
41
San antonio
Thank you so much for taking the time, super valuable!🙌🏻
That looks awesome!!!
