New pool owner, purchased home where previous owner had pool for many years. I have learned a lot about the system through trial and error but current issue has me stumped. It is a complete pentair filtration/pump/heater set up. Pool and spa combo with spa slightly raised with spillover.
When heating the spa i lose water from the spa to the pool. It happens slowly and when the spa mode is turned off it will resume normal water level. The system has two automatic actuator valves that seem to be working correctly as they move in tandem closing off the pool side when spa mode is turned on and vice versa spa mode is turned off.
Could i have a bad valve or possibly need to replace the internals, like the diverter? Or should i check something else first?
