Hi everyone,
When I set my valves to circulate the spa it's about 10 psi higher than if I run the pool plus spa (pool and spa returns on, main drain and skimmer on, spa drain off). Also the pump has a noticeable amount of air inside vs none when running the pool plus spa. Is this normal or do you think there's a suction side air leak in the spa?
