Hello, I am new to this group and a new pool owner as I just bought a house. My kids were very excited about the hot tub in this new house and sadly it is not operating correctly.
The pool has a Pentair MiniMax 400. This is an old model heater. This heater only has one service light and it does not tell you what the error is like newer models.
After heating for 10 minutes or so, it begins to cycle with service light coming on and off. As you can imagine, the cycling makes it take hours to heat the spa. It cycles about every five minutes.
What I have already tried:
1). Put in new high limit switches. Also tried bypassing them. Did not correct the issue.
2). Changed the thermastor with a new one. Did not correct the issue.
3). Installed a new thermal regulator. Did not correct the issue.
4). Bypassed the pressure switch. Did not correct the issue.
5). Tested heating just the pool rather than spa to see if there was some issue with the spa. Problem occurred just the same heating pool versus heating spa.
At this point, I am all out of ideas. I thought the the above would have fixed it. What other sensors Or switches are there that would cause the service light to come on intermittently??
Brandon
Brandon
