As the title said, I'm getting no water flow over the spa overflow. The spa does not seem to be able to fill high enough to get the waterfall to flow. The way the plumbing works, all suction is coming from the pool skimmer and main drain and flowing through the spa and overflow back into the pool.
Our pool company came 2 weeks ago for one of our bi-monthly service visits and I noticed it after that. I was also having trouble getting the pump to prime at all, especially if I set it to only pull from the skimmer. I assumed they had clogged the skimmer line while cleaning so I called and they sent out a supervisor last Thursday to take a quick look. He managed to get the pump running again by splitting the suction between skimmer and main drain and putting the pump in overdrive mode. The spa overflow worked then as well, if weaker than normal for when the pump is on its highest setting. But starting last Saturday, even on overdrive, the overflow stopped flowing. Then I tried using the spa on spa only mode that night and noticed that the jets also were not working. It's not been another week and the spa is starting to turn green. I don't really fully understand how the pump is even running at all - if all the water is returning through the spa, but no water is coming over the overflow, then how is the pool and the spa staying at the same level?
A couple of key clues:
* The filter is showing very high pressure (25 to 35 psi)
* Jets don't work either
* Pump will not stay primed if I switch to only pull from the skimmer. I see flow at the skimmer, so it's pulling some when you split between skimmer and drain, but it starts to really struggle if I isolate suction to skimmer only
The pool company is sending a repair guy to look on Monday, but any advice on ways to potentially fix it and get it running myself this weekend would be appreciated! I'd love to be able to use it this weekend and it costs $130 just to get the repair guy out to look at it, so I wouldn't mind just taking care of it myself if it's possible.
