Spa heater water leak
This past week I was able to get the heater back on. After I disconnected the gas line from the heater I opened and closed the gas valve several times and I could hear water sloshing around in the gas pipe. I used a shop vac to blow the water out and left it running for a couple of hours and did the same thing the next evening. Put it back together and had to cycle it on/off a few times to fill the gas line and then fired it up. Let it go for about 15 minutes with no problems. I will run it longer this weekend.
Thanks for all ideas, tips, etc
