- Mar 3, 2024
- 22
- Plaster
- Hayward Aqua Rite (T-9)
ON Easy Touch
If I understand correctly they want the pool turned to off but when that is done theheat never turns on.Ohhhhhhh K ..... Are you using the fireman's switch to control the HP? If so, the heat pump needs to be nailed into SPA mode. The HP doesn't know if it is needed for the pool or the spa so needs to be forced to spa only. That is what the above directions say to do.
Was referring to Hayward as they. I am the owner of the pool.Who is "they"? Are you the owner of this pool?
if I set it to off per instructions theheat never turns on.
Someone had posted the instructions here but I no longer see them.Please show us those instructions.
I think you are confused about how your HP operates but I cannot help you without seeing what caused your confusion.Someone had posted the instructions here but I no longer see them.
go back about 8 threads and they are there.Please show us those instructions.
