Ok to to clarify as it’s always been in this position since we moved in. You want me to shut off the below once the spa is full in yellow where the line is .
My next question would be can I leave it in this position or do I need to change it
Thanks all I’m confused
as I’ve never touched this value and never had an issue with the spa draining down
That makes no sense.in going to shut it off now and run the spa to fil and report back
When you closed the valve did the spillover stop while in Pool mode?I’ve now closed the Valve as suggested
Good, we know the likely culprit.I just turned the pump on and no water is coming into the spa.
I prefer Hawaii. Florida is too flat and cold in the winter.Thank you my friend I’m hoping Florida is your winter destination as I owe you
Spa light correct
