I walked out to my pool this morning and saw that the spa was drained. I went over to the pump / filter equipment and there was very little water in the basket filter. I immediately turned off the pump.
In researching I have read that there are a few potential causes for this.
Thank you for your assistance.
- Blocked inlet on the pump impeller
- checked and couldn't find any obstructions. I filled the basket filter and turned the pump back on and it drained it so I think that it is okay
- There is nothing blocking the skimmers that I can see
- In the attached pictures I can move the upper valve actuator with the switch on the side. I am not able to mover the lower one
- Is this the valve that could be block water coming into the pump?
- Is that a check valve on the left side of the plumping? If so, how do I verify that it is working correctly?
