Spa does not like to run at 100% speed
frogbite
2
Mirritt Island/Florida
Hi,
I have an Aqualogic automation setup. I also have a Hayward VSP. In pool mode, everything works great. When I put it into spa mode, the heater kicks on and runs at 100% for 10-15 minutes, maybe longer but eventually drops to 50%. When I look at the display on the Aqualogic controller it shows the speed at 50% and it is indeed running at 50%.
The VSP is setup for remote opeartion and is set to "Pool Filter" for the channel. I can not find anything in the menus regarding setting a secondary speed for the spa and when I go into the configuration there is a single setting for spa speed and it is 100%. Been through the menus many times and I am at a loss as to what is dropping the speed to 50%.
Any ideas?
ajw22
19,298
Northern NJ
Welcome to TFP.
Any ideas?
Configuration on the Aqualogic or on the pump?
Menus on the Aqualogic or on the pump?
