Sound level of Hayward Tri Star
Justadba
Active member
Mar 28, 2020
28
McKinney Texas
I am in need of replacing my Hayward North Star. It appears, (based on specs sheets) that’s Tri Star is or is very close to a drop in replacement. Minimum plumbing
My concern is the sound level of the Tri Star. My current northstar is 80 db standing right over it
Does anyone on here have input as to sound levels. Not expecting an actual db reading, but at least sound perception.
I have the 2.7hp ( not at home ) and after I installed it and had it running I walked back out side and thought it wasn’t running!
I saw the filter pressure before I ever heard the pump of that helps.
Some RPM’s are a little louder but I love it
A single speed Tristar shouldn't be any noisier than your old Northstar. Your old Northstar probably has increased bearing noise due to wear.
Consider getting a VS pump. It is considerably cheaper to run. Running at 1725 rpm versus 3450 rpm will use approximately 1/4 the electricity. Running at 1000-1200 rpm uses only around 100 watts. You can run longer at a lower rpm and still save money.
I run my VS pump 24/7 and it costs less than $20/month in electricity.
Ok. So the Tristar vsp sp3206vsp shows 1.85 hp. My North Star shows 2.0 hp. 1.35 SF. would the Tristar be ok? I’ve read/heard lower hp in newer models is equivalent to higher in older ones
True/false
The higher the HP, the slower you can run it to provide the same flow - so the 2.7hp is cheaper to run than the 1.85hp to move the same amount of water as the rpm will be lower for the same flow. The impellers are different, the 2.7hp moves more water per revolution.
Reactions: Justadba
I think the 2.7 was $200 more and I run all my returns open and have a water fall spa and it’s more then enough at 1700rpm. Old 1.6hp VS ran at 2800 and I had to keep the pool returns half closed.
It’s more then I ever thought I would pay for a pump but it’s a beast
True/false
The old Northstar pumps were, basically, too much pump for most applications. They had special motors with high service factors and moved tons of water. I actually had the Hayward engineers tell me that I should use a different pump on 3 different projects because of that, they would move too much water. There were other issues as well and Hayward discontinued them in favor of the TriStar, an excellent pump itself.
You don't give any information about your pool so just asking, "Will this pump work?" is difficult to answer, but a 2.7thp VSP will work on any pool. At first, the only readily available VSP were Pentair's original, and they had a total horsepower rating of 3.8 - 3.9 (every box had a slightly different label). You just turned them to slower speeds depending on application.
Brand new pumps are quiet. The W3SP3215EE pump you reference is a single-speed 1.5hp with a service factor of 1.5; 2.25thp (No longer legal in the US.). At 40ft. head (an average starting head on a pool system) that pump is going to try to move about 135gpm. Unless you have 2.5" or 3" plumbing your pipes (2", most likely), for pool purposes, should only have about 60gpm going through them at the most (7 ft. per second flow). If you slow the water down even more and run the pump (VSP, of course) longer you will get better results with your pool and great energy savings.
The single-speed pump will keep trying to push its rated amount, use and waste the energy because it can't, pressures will be high, and it could result in more noise than you are willing to accept.
