Okay, Ive got an equipment question, and Im not even sure what Im asking, but here goes. In reading up on solar heating, and what my system is (7 4 x 10 panels), Im finally getting to understand how it works. It appears the optimum rate for solar is 3-5 gallons per minute thru the panels. So I went to the Jandy calculator, and running my 1.65 pump at 1400 RPM gives me 31.5 gallons/minute, which I figure is close enough to what I need for solar (7 panels x 4 gpm = 28 gpm). So I went outside and turned on my solar, and set my pump to 1400 RPM....and the SWG turned off. So Im figuring the RPM is too low to run both the SWG and the solar. I played with the RPMs and when I got to 1800, the SWG kicked back on. So I figure thats were I need to be....except when I figure my Solar on 1800 RPMs, Ive got about 40 gpm, which seems way too high to efficiently run my solar. So Im not even sure Im figuring any of this correctly, can someone interpret this mess?
