My pool has the full Pentair EasyTouch 8P setup with a 3-way valve for directing the water either to the pool or to the rooftop solar heat collectors.
Is there a way to turn the solar valve on or off from the Screenlogic interface regardless temperature? When I turn the solar switch on or off, the easytouch still takes the temperature difference into account and only works in the automatic mode. When the clouds move in once in a while, the valve turns to the other position emptying the collector panels.
I would like to set a manually created schedule for the solar valve and have it work regardless of the temperature difference. Is that possible anywhere on Screenlogic interface or do I have to rewire a few things?
