So I knew I'd have some sprinkler damage but I was hoping it would be just one line that had to go through the pool. I got 9 halves.
and it looks like they did loop-dee loos because only 2 line up, with this one went to that one. I'm just not going to make any sense out of it.
So i will run through the zones that are back there and find/ label my feeds when they squirt. Then I will takr one long piece and connect a feed to each of the 'extras' and label them. I made a map of the property when I moved in with the zones/heads so even if some of the heads are buried under the dirt pile, only one has to fire and I'll know that's zone 12 (?). Then its connect the halves.
But. Another chapter of Newdude's guide to making lemonade......
where the Negative Nancy's see extra damage, I see easy access to 1 inch fill pipes. My plans were to cut and tap the house feed which is 1 inch (coincidentally where the sprinklers connect) and run a sprinkler pipe through the basement window out to the pool. But now that I have several out there, it's much easier. By the time they wrap around the house they lose some oomph so I'll probably use 2.
