Re: Should I just give up? Can
The slam will continue until it's done, no matter how long it takes!
Just to confirm (and since I haven't seen anyone ask in a while)...you're still running your filter 24/7 during the process, correct?
What does the water look like? Do you have any lights in the pool?
looks good! you are heading for the homestretch. keep SLAMMING til she looks like this:
and CC is .5 ppm or less
and you have no more than 1 ppm loss of FC overnight. Test right at dark, then again the next morning before the sun hits the pool.
FC maintained at 20 all night, CC is down to 1 .... the water is looking more clear. But I still can't see the bottom of the pool
Just confirming again as you didn't reply. I'm sure the answer is yes, but just checking.![]()
Make sure you are backwashing the filter when it's pressure reaches 25% higher than clean pressure. Read Maintenance and Cleaning of Pool Filters for detailed instructions.
I think that still sounds normal. Cloudy (not hazy) water can take a long time to clear with a sand filter after all the algae is dead.
