I can’t wait til it’s done!...the steps seem small though, and a lot of them! lolAnother big step towards having a nice pool to jump in and enjoy!!!
I can’t stand mosquitoes, they are the worst...I think I might get Mosquito Authority in to spray.What is that??? SAND??? SWEET! Now don't feed them blood suckers too much!!
Kim![]()
I’ll check it out, thanks!Look into getting an OFF mosquito lamp that used the "pads". They are like having a "dome" over you!
Kim![]()
Actually they are!...couldn’t have done it without them! lolBet the wheel barrow and shovels are NOT your friends right now LOL I hope that is enough to cover the area.
Kim![]()
I am using foam cove, I didn’t really like the idea of a sand cove.It does look like a pool now! Good job! gurrrrrrrrrrr on the rain but I bet it did feel good!
I forget, are you using foam cove or using the sand?
Kim![]()
Thanks!...I will look closer at the wall tomorrow after I clean it up a little, thanks for the tip!Looking good!
If there are any areas that look like the paint is coming off or small rust spots, now would be the time to spray with rust inhibitor paint. It will take a day or two in the humidity to dry. If its hot sun, it does not cure well. Ask me how I know.ale:
We did get a little done today after work before the mosquitoes came out. I finished planting the last block so I could get the other 2 delta uprights bolted in...
We also started bringing the sand in, but it was too dark to snap a pic.
Thanks!Following your thread and it is great!
On the mosquitoes, get a 96 fl.oz. jug of Bifen I/T off amazon, treat the whole yard once, and then again a week or two after. Treat then every three months. Mosquitoes will be gone after the week or two treatment, all other bugs will be gone after the first treatment. 96 fl.oz makes 96 gallons, and each gallon will treat about 1000 sq.ft. (if I remember correctly). $35 for the Bifen I/T and $10 for a 2 gallon sprayer - beats by far (a factor of 10x) the cost of the big store pre-diluted gallon jugs and for the same coverage but better performance and you DIY it. The only problem is it takes a little longer to get rid of sweat bees.
Bifen I/T
Search also for other recommendations of Bifen on TFP.
Exactly!...that’s why I went with the foam cove.GOOD! I was thinking about your sand piles and how much of it would be taken if you used it to make a cove. I do NOT like sand for a cove. To me there is too much of a chance of it washing out. Then the liner could sneak out under the wall![]()
I’m not sure what you mean by 12” steppers...maybe we call it something different?...or I just have no idea what you’re talking about. lolkimkats said:Okay here is a couple of tips for you. Thanks!
-hard plumb with schedule 40 pipe.
Done!
-Have a valve under the skimmer and return so you can close them when you need to work on the equipment.
Done!
-unions on everything so you do not have to cut pipe to work on it or remove it
Done!
-under you skimmer and return.......dig down about 3" and out far enough to put a couple of 12" steppers or such. Fill the hole back up with gravel. Cover with the steppers making sure they have a slight slant away from the pool. Use care to not have the rocks or steppers touching the pool. This will help keep the skimmer overflowing from washing out your sand bottom. I see this as planning ahead for large rain, pipe failure, etc. I also learned this from experience before we hard plumbed and one of the hoses came off![]()
Kim![]()
