C-4030 Hayward Filter (I think... it's a 4 filter in ground system, but I often get the size wrong)
Bit the bullet and replaced my old OEM Hayward filters with new Pleatco filters based on a bunch of research and $75 lower price. Haven't had them in long enough to review them, but running into a weird issue.
When I put in the new filters I noticed that my default PSI at 100% pump speed is about 2 PSI higher than it was with the Hayward OEMs. Those OEMs maintained that filter pressure more or less throughout their life whenever they were cleaned.
So I'm wondering if this is to be expected or if I should be concerned? Do brand new filters often run a little high until their saturated? Does the different material in the Pleatcos have more resistance than the Haywards? I dutifully cleaned out the filter body and all the parts (hose, wet dry vac) before reinstalling everything, and was pretty rigorous on reassembly (pushed down the cap fullt, etc). It's running fine, it's just that the PSI is a little high.
Not a huge issue, but as someone who dutifully maintains my pool kit I like to make sure I know why things are happening. I can pull the whole thing apart again, though I really dont want to...
Thanks!
Rick
Thanks!
Rick
